Ga door naar hoofdinhoud
SPÖKA IKEA Battery Replacement
Wat je nodig hebt
  1. SPÖKA IKEA Battery Replacement, Battery replacement: stap 1, afbeelding 1 van 1
    • The most tricky part is to get the inner body out of the rubber shell.
    • I was supprised. The rubber can actually take some stretching
    • you end up with an egg shaped plastic body
  2. SPÖKA IKEA Battery Replacement: stap 2, afbeelding 1 van 1
    • Now we need to remove the bottom cap.
    • carefully bend the two hoocks inwards (e.g. with a small screwdriver) ad remove it
    • Now you can split the the body into two
  3. SPÖKA IKEA Battery Replacement: stap 3, afbeelding 1 van 1
    • you now can extract the battery pack.
    • on top you see the little switch to turn it on and off.
    • the LED are strapped with a cable tie around the battery
    • at the bottom lies the connector for recharging
  4. SPÖKA IKEA Battery Replacement: stap 4, afbeelding 1 van 1
    • remove the cable tie
    • remove the warapping of the battery pack
    • desolder the two cables from the pack
    • now it should look like the pack on the right
    • glue the new batteries together. - keep in mind, to alter the ends.
    • at the end you should have a new pack with (+) (-) (+) at one end and (-) (+) (-) at the other
  5. SPÖKA IKEA Battery Replacement: stap 5, afbeelding 1 van 1
    • this is the tricy part.
    • the new pack should be facing you with (+) (-) (+)
    • solder the right (+) to the (-) in the middle
    • Lolder the upper left (-) to the (+) in the middle
    • I used some old wire for it
    • Now solder the short black wire to the upper (-). It must be the only (-) with no connection yet
    • Solder the red long wire to the lower left (+). Also this must be the only (+) left without any connection
    • let it cool off
  6. SPÖKA IKEA Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the cable tie to strap the LED back to the battery pack
    • isolate the open ends of the batterypack. It must not be able to create a short circuit. I used the hot glue. but also some thick rubber tape can do the job
    • put it back together in the shell
    • be aware to place the switch and the connector for recharging on the right places
    Hello! My daughter and her friends played soccer with this light
    Tomas McGarry - Antwoord
  7. SPÖKA IKEA Battery Replacement: stap 7, afbeelding 1 van 1
    • Now its getting ugly again.
    • you have to put the shell back into the rubber
    • this could take a while
    • Be aware to put the connector on the right side, so you are able to recharge it again
  8. SPÖKA IKEA Battery Replacement: stap 8, afbeelding 1 van 1
    • Switch it back on and enjoy the bright light
    • Please remember that you altered a electric device.
    • never let your new spöka charge unattended and keep a good eye on it for short circuits
Conclusie
be aware that you altered an electric device!!!
If you do not know what you are doing... dont to it
Colin
223 Reputatie
1 Handleiding geschreven
Één opmerking
This is a good writeup. One flaw is the old battery photo doesn’t show the markings — not everyone will want to hot-glue a NiMH battery pack from scratch, when you can purchase 4 for $10 on Amazon (from a baby monitor or cordless phone). These they have the advantage of using JST connectors (though you’d need to solder on a socket to take advantage of that).
ALSO - if you have the “fat Spoka” as I do, it uses 3 NiMH formed in a triangle (byd nimh battery h-aaa550X3) and those are IMPOSSIBLE to find so no retail option there — I probably will have to hot-glue the battery pack… :-)
scootz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 51
Altijd: 14,896
