Ga door naar hoofdinhoud
SONY SRS-X2 Charger Port Replacement
Wat je nodig hebt
  1. SONY SRS-X2 Charger Port Replacement, Face Plate: stap 1, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement, Face Plate: stap 1, afbeelding 2 van 2
    • Use the metal spudger to pry the face screen open. Pull away from the device to remove.
  2. SONY SRS-X2 Charger Port Replacement: stap 2, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement: stap 2, afbeelding 2 van 2
    • Remove seven, 27 mm long Phillips #1 screws.
    • Remove three, 11mm long Phillips #1 screws.
    • Remove four, 10 mm long Phillips#1 screws.
  3. SONY SRS-X2 Charger Port Replacement: stap 3, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement: stap 3, afbeelding 2 van 2
    • Before removing the host plate, face the feet of the speaker to you. The wiring allows for minimal access to the inner components.
    • Use the spudger to remove the speaker host plate. Insert the metal tip in the seam between the host plate and the shell.
    • Be very careful when pulling the speaker host plate (described in the next step) as there are wiring connected to the host plate. This wiring is soldered to the plate and to the shell of the device. The wires are flexible and you can still open the device as shown in the second picture.
    • Center the spudger on the top of the device, this is furthest from the wiring, in wiggling the spudger under the plate, the plate should move up and out of the shell, you can finish lifting the plate away with your fingers.
  4. SONY SRS-X2 Charger Port Replacement: stap 4, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement: stap 4, afbeelding 2 van 2
    • Be gentle when using the opening tool, wiggle the opening tool on each side of the socket to be sure the plastic does not snap.
    • Be careful not to damage the wires, pull from the plastic base to unplug.
    • Unplug the power cable connector shown using the plastic opening tool. Wiggle the tool under the lip of the plug, the smaller area and odd angle means lifting up with the plastic tool in the setup shown.
    • Unplug the power connector shown using the plastic opening tool lift from the front of the plug shown and move the opening tool to either side to get it all the way out of the socket.
  5. SONY SRS-X2 Charger Port Replacement, Battery: stap 5, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the four, 11 mm, Phillips#1 screws on the battery cover plate.
  6. SONY SRS-X2 Charger Port Replacement: stap 6, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement: stap 6, afbeelding 2 van 2
    • Remove the battery cover plate carefully then proceed to remove the battery.
  7. SONY SRS-X2 Charger Port Replacement, Charger Port: stap 7, afbeelding 1 van 2 SONY SRS-X2 Charger Port Replacement, Charger Port: stap 7, afbeelding 2 van 2
    • Use PH1 screwdriver to remove two 11mm Phillips #1 screws on the charger port.
    • Gently pull out the charger port with fingers for replacement.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Yubei Wu
662 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-3, Sullivan Fall 2016 Lid van USF Tampa, Team 3-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G3
4 Leden
6 handleidingen geschreven
9 opmerkingen
Hi, is there a recommended replacement part to use for the speaker?
cwodnet - Antwoord
I would find the link for the customer service. You might be able to get the port from the SONY site.
Yubei Wu - Antwoord
Where can I buy an USB charger repair kit (complete) for Sony SRS x2? piechmagdalena35@gmail.com
mag.pi - Antwoord
Where i can find the charger port for the speaker sony? somebody could help me?
alfredotanchez@gmail.com
Alfredo - Antwoord
My SRS-X2 will connect via bluetooth, I can hear for the sound briefly then stops. I know it still connected because the sound from my laptop is off, until I switch off the SRS to restore sound on my laptop.
If anyone experienced the same and have idea how to fix it, please notify me.
veortiz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 45
Altijd: 8,036
