Ga door naar hoofdinhoud
SONY Ericsson W890i Motherboard Replacement
Wat je nodig hebt
  1. SONY Ericsson W890i Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
  2. SONY Ericsson W890i Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Pop the back cover up using the groove on the top of the phone.
  3. SONY Ericsson W890i Motherboard Replacement: stap 3, afbeelding 1 van 1
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
  4. SONY Ericsson W890i Motherboard Replacement, Keypad and Front Cover: stap 4, afbeelding 1 van 2 SONY Ericsson W890i Motherboard Replacement, Keypad and Front Cover: stap 4, afbeelding 2 van 2
    • Remove the two small rubber pieces that cover the lower screws.
    • Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
  5. SONY Ericsson W890i Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Gently pry off the faceplate using a plastic opening tool.
    • Insert the plastic opening tool into the middle of the front and back panels of the phone.
  6. SONY Ericsson W890i Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Separate the front and back panels that were pryed open with the plastic opening tool.
  7. SONY Ericsson W890i Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Now that the faceplate is off, use tweezers to separate the backplate from the inner manifold.
  8. SONY Ericsson W890i Motherboard Replacement: stap 8, afbeelding 1 van 1
    • With both insides of the phone exposed, gently detach the ribbon cable connecting the two inner sides. You can now separate the two sides of the phone.
  9. SONY Ericsson W890i Motherboard Replacement: stap 9, afbeelding 1 van 1
    • The motherboard is located on the side with the green and black bumper on the bottom. Use the plastic opening tool to pry the bumper off.
  10. SONY Ericsson W890i Motherboard Replacement: stap 10, afbeelding 1 van 1
    • To remove the motherboard, apply upwards pressure on the bottom green tab.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bob
316 Reputatie
3 handleidingen geschreven
SUNY Cortland, Team 1-3, Getto Spring 2013 Lid van SUNY Cortland, Team 1-3, Getto Spring 2013
SUNYCORT-GETTO-S13S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 997
