Inleiding
Use this guide to replace the two speakers on your Skytex SP1020.
Wat je nodig hebt
Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
Één andere persoon heeft deze handleiding voltooid.
