Ga door naar hoofdinhoud
SHARP EL-W53XG WriteView Battery Replacement
Wat je nodig hebt
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: stap 1, afbeelding 1 van 2 SHARP EL-W53XG WriteView  Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: stap 2, afbeelding 1 van 1
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: stap 3, afbeelding 1 van 2 SHARP EL-W53XG WriteView  Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: stap 4, afbeelding 1 van 2 SHARP EL-W53XG WriteView  Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: stap 6, afbeelding 1 van 1
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
Conclusie
Faduma Hagi
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 49
Altijd: 1,429
