Ga door naar hoofdinhoud
SHARP EL-546XT Battery Replacement
Wat je nodig hebt
  1. SHARP EL-546XT Battery Replacement, Battery: stap 1, afbeelding 1 van 2 SHARP EL-546XT Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: stap 2, afbeelding 1 van 3 SHARP EL-546XT Battery Replacement: stap 2, afbeelding 2 van 3 SHARP EL-546XT Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: stap 3, afbeelding 1 van 3 SHARP EL-546XT Battery Replacement: stap 3, afbeelding 2 van 3 SHARP EL-546XT Battery Replacement: stap 3, afbeelding 3 van 3
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: stap 4, afbeelding 1 van 2 SHARP EL-546XT Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: stap 5, afbeelding 1 van 3 SHARP EL-546XT Battery Replacement: stap 5, afbeelding 2 van 3 SHARP EL-546XT Battery Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: stap 6, afbeelding 1 van 3 SHARP EL-546XT Battery Replacement: stap 6, afbeelding 2 van 3 SHARP EL-546XT Battery Replacement: stap 6, afbeelding 3 van 3
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: stap 7, afbeelding 1 van 2 SHARP EL-546XT Battery Replacement: stap 7, afbeelding 2 van 2
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: stap 8, afbeelding 1 van 3 SHARP EL-546XT Battery Replacement: stap 8, afbeelding 2 van 3 SHARP EL-546XT Battery Replacement: stap 8, afbeelding 3 van 3
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: stap 9, afbeelding 1 van 3 SHARP EL-546XT Battery Replacement: stap 9, afbeelding 2 van 3 SHARP EL-546XT Battery Replacement: stap 9, afbeelding 3 van 3
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
Eindstreep
Mithunan Sivagnanam
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 480
