Ga door naar hoofdinhoud
SGH-A117 keypad replacement
Wat je nodig hebt
  1. SGH-A117 keypad replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
  2. SGH-A117 keypad replacement: stap 2, afbeelding 1 van 1
    • Lift the bottom of the battery and then move it up and away.
  3. SGH-A117 keypad replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
  4. SGH-A117 keypad replacement: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
  5. SGH-A117 keypad replacement: stap 5, afbeelding 1 van 1
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
  6. SGH-A117 keypad replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
  7. SGH-A117 keypad replacement, Keypad: stap 7, afbeelding 1 van 1
    • After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
  8. SGH-A117 keypad replacement: stap 8, afbeelding 1 van 1
    • Replace the faulty keypad, and reassemble the phone.
Conclusie
Stephanie Isaac
431 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 47
Altijd: 484
