Ga door naar hoofdinhoud
SG 552-1 Commando Barrel Replacement
Wat je nodig hebt
  1. SG 552-1 Commando Barrel Replacement, Barrel: stap 1, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement, Barrel: stap 1, afbeelding 2 van 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: stap 2, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: stap 3, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 3, afbeelding 2 van 2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: stap 4, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 4, afbeelding 2 van 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: stap 5, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 5, afbeelding 2 van 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: stap 6, afbeelding 1 van 3 SG 552-1 Commando Barrel Replacement: stap 6, afbeelding 2 van 3 SG 552-1 Commando Barrel Replacement: stap 6, afbeelding 3 van 3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: stap 7, afbeelding 1 van 2 SG 552-1 Commando Barrel Replacement: stap 7, afbeelding 2 van 2
    • Remove the remaining pieces of on the ends of the barrel.
Conclusie
Laura Schulz
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-41, Regan Fall 2012 Lid van Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,671
