Ga door naar hoofdinhoud
SCUF Reflex Joystick Replacement
Wat je nodig hebt
  1. SCUF Reflex Joystick Replacement, Remove the middle trim: stap 1, afbeelding 1 van 1
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips.
    • Loosen the rest of the clips and take the middle trim out.
  2. SCUF Reflex Joystick Replacement, Remove L1 and R1: stap 2, afbeelding 1 van 3 SCUF Reflex Joystick Replacement, Remove L1 and R1: stap 2, afbeelding 2 van 3 SCUF Reflex Joystick Replacement, Remove L1 and R1: stap 2, afbeelding 3 van 3
    • Use a tool to pop the R1 and L1 buttons off of the controller.
  3. SCUF Reflex Joystick Replacement, Unscrew the grips: stap 3, afbeelding 1 van 2 SCUF Reflex Joystick Replacement, Unscrew the grips: stap 3, afbeelding 2 van 2
    • Unscrew and remove the screw from the bottom of each grip.
  4. SCUF Reflex Joystick Replacement, Unscrew behind L1 and R1: stap 4, afbeelding 1 van 1
    • Unscrew the screws behind the L1 and R1 buttons.
  5. SCUF Reflex Joystick Replacement, Pull the joysticks off: stap 5, afbeelding 1 van 2 SCUF Reflex Joystick Replacement, Pull the joysticks off: stap 5, afbeelding 2 van 2
    • Pull the joysticks off of the controller.
  6. SCUF Reflex Joystick Replacement, Pull the scuff buttons off: stap 6, afbeelding 1 van 1
    • Pull the scuff buttons off the back of the controller by sliding them down.
  7. SCUF Reflex Joystick Replacement, Remove the rear case: stap 7, afbeelding 1 van 2 SCUF Reflex Joystick Replacement, Remove the rear case: stap 7, afbeelding 2 van 2
    • Slide the prying tool down the edge of the rear casing of the controller to remove the rear case.
    • Be sure to deal with all the clips!
  8. SCUF Reflex Joystick Replacement, Slide the battery out: stap 8, afbeelding 1 van 2 SCUF Reflex Joystick Replacement, Slide the battery out: stap 8, afbeelding 2 van 2
    • Slide the battery out of the controller. It's grey and held in by a couple of wires, so be careful not to damage them.
  9. SCUF Reflex Joystick Replacement, Unplug the battery: stap 9, afbeelding 1 van 1
    • Unplug the battery to finish removing the battery from the controller.
  10. SCUF Reflex Joystick Replacement, Take the battery bracket out: stap 10, afbeelding 1 van 2 SCUF Reflex Joystick Replacement, Take the battery bracket out: stap 10, afbeelding 2 van 2
    • Unscrew the screw on the back of the controller to remove the battery bracket.
  11. SCUF Reflex Joystick Replacement, Desolder the ribbon cables: stap 11, afbeelding 1 van 2 SCUF Reflex Joystick Replacement, Desolder the ribbon cables: stap 11, afbeelding 2 van 2
    • Use a soldering iron to desolder the ribbon cables on the motherboard.
  12. SCUF Reflex Joystick Replacement: stap 12, afbeelding 1 van 1
    • Unplug these four cables from the motherboard.
  13. SCUF Reflex Joystick Replacement: stap 13, afbeelding 1 van 1
    • Use the soldering iron to desolder the black and red wires off of the motherboard.
  14. SCUF Reflex Joystick Replacement: stap 14, afbeelding 1 van 1
    • Remove the motherboard and the battery bracket from the controller to expose the joystick component.
  15. SCUF Reflex Joystick Replacement: stap 15, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Desoldering Pump
    $3.99
    • Use the soldering iron and the desoldering pump to desolder the 14 connections for the component.
  16. SCUF Reflex Joystick Replacement: stap 16, afbeelding 1 van 1
    • Remove the component from the motherboard.
  17. SCUF Reflex Joystick Replacement: stap 17, afbeelding 1 van 2 SCUF Reflex Joystick Replacement: stap 17, afbeelding 2 van 2
    • Put the new component on the motherboard.
    • Use the soldering iron to connect the new component to the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tri Truong
429 Reputatie
2 handleidingen geschreven
1Gids Commentaar
Hi! Wich replacement component do you use?
Antonis Lambropoulos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 38
Afgelopen 7 dagen: 202
Afgelopen 30 dagen: 734
Altijd: 15,717
