Ga door naar hoofdinhoud
Ryobi RS290G Motor Replacement
Wat je nodig hebt
  1. Ryobi RS290G Motor Replacement, Top Cap: stap 1, afbeelding 1 van 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Motor Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Motor Replacement: stap 3, afbeelding 1 van 1
    • Remove the top cap.
  4. Ryobi RS290G Motor Replacement, Switch Trigger: stap 4, afbeelding 1 van 1
    • Remove the switch trigger.
  5. Ryobi RS290G Motor Replacement, Motor: stap 5, afbeelding 1 van 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Motor Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Motor Replacement: stap 7, afbeelding 1 van 2 Ryobi RS290G Motor Replacement: stap 7, afbeelding 2 van 2
    • Slide the power switch out of the housing assembly.
  8. Ryobi RS290G Motor Replacement: stap 8, afbeelding 1 van 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Motor Replacement: stap 9, afbeelding 1 van 2 Ryobi RS290G Motor Replacement: stap 9, afbeelding 2 van 2
    • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
  10. Ryobi RS290G Motor Replacement: stap 10, afbeelding 1 van 2 Ryobi RS290G Motor Replacement: stap 10, afbeelding 2 van 2
    • Slide out the brush assembly with the black lead from the inner housing assembly.
  11. Ryobi RS290G Motor Replacement: stap 11, afbeelding 1 van 1
    • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
    • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
  12. Ryobi RS290G Motor Replacement: stap 12, afbeelding 1 van 1
    • Remove the armature assembly, with the motor, out of the inner housing assembly.
  13. Ryobi RS290G Motor Replacement: stap 13, afbeelding 1 van 3 Ryobi RS290G Motor Replacement: stap 13, afbeelding 2 van 3 Ryobi RS290G Motor Replacement: stap 13, afbeelding 3 van 3
    • Replace the motor (also known as field assembly).
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 914
