Inleiding
This replacement guild will should how to replace the motor in the Ryobi RJ1861V.
Wat je nodig hebt
Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
The motor is divided into two sections, one attached to the gear case and one attached to the handle.
This arrow indicates the section attached to the gear case.
This arrow indicates the section attached to the handle.
Één andere persoon heeft deze handleiding voltooid.
