Ga door naar hoofdinhoud
Ryobi RJ1861V Motor Replacement
Wat je nodig hebt
  1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: stap 1, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Replacement: stap 2, afbeelding 1 van 2 Ryobi RJ1861V Motor Replacement: stap 2, afbeelding 2 van 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Replacement: stap 3, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Replacement: stap 4, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Replacement: stap 5, afbeelding 1 van 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Replacement: stap 7, afbeelding 1 van 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: stap 8, afbeelding 1 van 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Replacement: stap 9, afbeelding 1 van 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Replacement: stap 10, afbeelding 1 van 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Replacement, Motor: stap 11, afbeelding 1 van 1
    • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
    • This arrow indicates the section attached to the gear case.
    • This arrow indicates the section attached to the handle.
  12. Ryobi RJ1861V Motor Replacement: stap 12, afbeelding 1 van 3 Ryobi RJ1861V Motor Replacement: stap 12, afbeelding 2 van 3 Ryobi RJ1861V Motor Replacement: stap 12, afbeelding 3 van 3
    • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
  13. Ryobi RJ1861V Motor Replacement: stap 13, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
  14. Ryobi RJ1861V Motor Replacement: stap 14, afbeelding 1 van 2 Ryobi RJ1861V Motor Replacement: stap 14, afbeelding 2 van 2
    • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
    • Flip the housing over and pull the motor up and out of the housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adrian Williams
183 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 233
