Ga door naar hoofdinhoud
Ryobi RJ1861V Assembly Bar Bearing Replacement
Wat je nodig hebt
  1. Ryobi RJ1861V Assembly Bar Bearing Replacement, Saw Bar Assembly: stap 1, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 2, afbeelding 1 van 2 Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 2, afbeelding 2 van 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 3, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 4, afbeelding 1 van 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 5, afbeelding 1 van 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 7, afbeelding 1 van 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Assembly Bar Bearing Replacement, Assembly Bar Bearing: stap 8, afbeelding 1 van 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 9, afbeelding 1 van 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Assembly Bar Bearing Replacement: stap 10, afbeelding 1 van 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 464
