Inleiding
Use this guide to remove the housing assembly of your Ryobi P517 reciprocating saw.
The housing assembly is the plastic outer shell of the saw that contains and protects the device's inner components. The housing assembly needs to be removed to access the inner components of the saw, such as the trigger assembly and the motor. A poorly assembled housing assembly can allow debris and/or moisture to enter and cause damage to the electrical components of the saw. Additionally, the housing assembly provides structure to the device, so its integrity is essential for user experience.
Before reading this guide, please review the Ryobi P517 Troubleshooting Page to ensure that your issue cannot be resolved externally, without removing the housing assembly. Remove the blade and battery from the saw before beginning the housing assembly removal process.
Wat je nodig hebt
Position the saw so you can access the button-clips on both sides of the battery.
Lay the saw flat so the left side is facing up.
Remove the grey orbital button by twisting it counterclockwise.
