Ga door naar hoofdinhoud
Ryobi P501G Trigger Replacement
Wat je nodig hebt
  1. Ryobi P501G Trigger Replacement, Shell: stap 1, afbeelding 1 van 3 Ryobi P501G Trigger Replacement, Shell: stap 1, afbeelding 2 van 3 Ryobi P501G Trigger Replacement, Shell: stap 1, afbeelding 3 van 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  2. Ryobi P501G Trigger Replacement: stap 2, afbeelding 1 van 3 Ryobi P501G Trigger Replacement: stap 2, afbeelding 2 van 3 Ryobi P501G Trigger Replacement: stap 2, afbeelding 3 van 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
  3. Ryobi P501G Trigger Replacement, Trigger: stap 3, afbeelding 1 van 1
    • After opening the shell, locate the black plastic trigger on the handle of the device.
  4. Ryobi P501G Trigger Replacement: stap 4, afbeelding 1 van 1
    • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
    • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
Conclusie
Sophia Arias
255 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G2, Maness Spring 2019 Lid van Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 1,638
