Inleiding
If you need to replace or fix and component of the Ryobi P214 cordless drill that is on the inside cast, use this guide to access the inside panel.
Wat je nodig hebt
Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
Bijna klaar!
Conclusie
