Ga door naar hoofdinhoud
Ryobi CSB135L Motor Replacement
Wat je nodig hebt
  1. Ryobi CSB135L Motor Replacement, Motor Housing: stap 1, afbeelding 1 van 1
    • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
    • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
  2. Ryobi CSB135L Motor Replacement: stap 2, afbeelding 1 van 1
    • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
    • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
  3. Ryobi CSB135L Motor Replacement: stap 3, afbeelding 1 van 1
    • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
  4. Ryobi CSB135L Motor Replacement: stap 4, afbeelding 1 van 1
    • Fully remove the motor housing and blade cover to expose the motor and laser.
  5. Ryobi CSB135L Motor Replacement, Motor: stap 5, afbeelding 1 van 1
    • Remove the two M4 x 16 mm screws using a Phillips screwdriver.
  6. Ryobi CSB135L Motor Replacement: stap 6, afbeelding 1 van 1
    • Rotate the saw completely around to view the bottom of the motor as shown.
    • Remove the two 4.2 x 2.54 x 50 screws using a Phillips screwdriver.
  7. Ryobi CSB135L Motor Replacement: stap 7, afbeelding 1 van 1
    • Pull out the motor assembly.
  8. Ryobi CSB135L Motor Replacement: stap 8, afbeelding 1 van 1
    • Follow the wires from the motor to the wire cover and black box and undo the fastening of those wires to finish removing the motor from the saw.
Conclusie
Nathanael Winchell
689 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 90
