Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the top row so that each corner is roughly halfway between the sides
Push the pieces up until they pop out of the cube, then, slide the rest out
Repeat this process until you clear the level
You should be able to just directly pull out the rest of the blocks, like so
And there you have it!
You'll have the center piece, with the six centers of the six sides, the turning mechanism
To reassemble, snap all the pieces back into place, and try not to rotate the faces.
It helps to start with the middle pieces first
Don't be afraid to use force!
Once you have the middle pieces in it's pretty simple to just push in the corner pieces
Again- don't be afraid to use force!
6 opmerkingen
that method just broke my rubiks my cube.. thanks anyway
