Ga door naar hoofdinhoud
Rubber Watch Battery Replacement
Wat je nodig hebt
  1. Rubber Watch Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Rubber Watch Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: stap 2, afbeelding 1 van 3 Rubber Watch Battery Replacement: stap 2, afbeelding 2 van 3 Rubber Watch Battery Replacement: stap 2, afbeelding 3 van 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: stap 4, afbeelding 1 van 3 Rubber Watch Battery Replacement: stap 4, afbeelding 2 van 3 Rubber Watch Battery Replacement: stap 4, afbeelding 3 van 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: stap 6, afbeelding 1 van 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: stap 7, afbeelding 1 van 3 Rubber Watch Battery Replacement: stap 7, afbeelding 2 van 3 Rubber Watch Battery Replacement: stap 7, afbeelding 3 van 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
Eindstreep
Lee
110 Reputatie
1 Handleiding geschreven
UC Davis, Team S2-G5, Cole Spring 2017 Lid van UC Davis, Team S2-G5, Cole Spring 2017
UCD-COLE-S17S2G5
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 769
