Inleiding
The tip switch is a bulb filled with mercury that turns a heater off if the device were to tip over. This function is to prevent fires and if the heater continues to run even when tipped over then replace the tip switch.
Onderdelen
Geen onderdelen opgegeven.
Flip the device over so the bottom is facing up.
Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
Remove the front panel by pulling them apart. The front panel should come out easily.
Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
