Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The thermostat regulates temperature, if you change the temperature, using the dial, and the heater is not responding then you need to replace the thermostat.
  1. Unplug the power cord.
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel. Remove the front panel by pulling them apart. The front panel should come out easily. Remove the front panel by pulling them apart. The front panel should come out easily.
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Remove the two dial caps from the two switches by lifting them up.
    • Remove the two dial caps from the two switches by lifting them up.
  4. Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
    • Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
  5. Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater. Unplug the wire that goes from the bottom  of the power switch to the heater coils.  To unplug pull down on the wire until it breaks free.
    • Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater.
    • Unplug the wire that goes from the bottom of the power switch to the heater coils. To unplug pull down on the wire until it breaks free.
  6. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  7. Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater. Unplug the wire that goes from the bottom of the power switch to the fuse holder.  To unplug the wire, pull the wire away from the fuse holder.
    • Unplug the wire that goes from the bottom of the power switch to the fuse holder. To unplug the wire, pull the wire away from the fuse holder.
  8. Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater.
    • Unplug the wires located on the right side of the heat coil housing. Both plugs will come off together. To unplug the wires, pull down on the wire until it breaks free.
  9. Grab the Switch and Circuit Board Assembly  with one  hand and slide it up.  You will need to wiggle it to break it loose.  While wiggling it, slide it up until it is clear of the plastic rails. Grab the Switch and Circuit Board Assembly  with one  hand and slide it up.  You will need to wiggle it to break it loose.  While wiggling it, slide it up until it is clear of the plastic rails.
    • Grab the Switch and Circuit Board Assembly with one hand and slide it up. You will need to wiggle it to break it loose. While wiggling it, slide it up until it is clear of the plastic rails.
  10. Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater. Unplug the two wires, with blue ends, that go from the Power/Fan switch and from the bottom of the Circuit Board to the fan.  To unplug the wires, pull them away from the fan assembly until they break free.
    • Unplug the two wires, with blue ends, that go from the Power/Fan switch and from the bottom of the Circuit Board to the fan. To unplug the wires, pull them away from the fan assembly until they break free.
  11. Pull off the black thermostat extension by pulling up. This should require very little force and should come apart easily.
    • Pull off the black thermostat extension by pulling up. This should require very little force and should come apart easily.
  12. Remove the nut from the thermostat using the adjustable wrench.  Place the wrench around the nut and turn it counter-clockwise.  Remove the thermostat/circuit board assembly from the gold metal bracket.
    • Remove the nut from the thermostat using the adjustable wrench. Place the wrench around the nut and turn it counter-clockwise. Remove the thermostat/circuit board assembly from the gold metal bracket.
  13. Flip over the circuit board
    • Flip over the circuit board
  14. Use the soldering iron to remove solder from the five points connecting the thermostat to the circuit board.  Pull the thermostat away from the circuit board.
    • Use the soldering iron to remove solder from the five points connecting the thermostat to the circuit board. Pull the thermostat away from the circuit board.
Conclusie
Luke Nora
210 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-35, Amido Fall 2013 Lid van Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 615
