Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
In order to access the other components, such as the fuse, fan, or circuit board, the front panel has to be removed.
The front panel will pop up easily.
Onderdelen
Geen onderdelen opgegeven.
  1. Unplug the power cord.
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel. Remove the front panel by pulling them apart. The front panel should come out easily. Remove the front panel by pulling them apart. The front panel should come out easily.
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Remove the two dial caps from the two switches by lifting them up.
    • Remove the two dial caps from the two switches by lifting them up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Long Tran
202 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-35, Amido Fall 2013 Lid van Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 86
