Ga door naar hoofdinhoud
RotoZip Rebel REB01 Type 2 Power Cord Replacement
Wat je nodig hebt
  1. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Saw Casing: stap 1, afbeelding 1 van 1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 2, afbeelding 1 van 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 3, afbeelding 1 van 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 3, afbeelding 2 van 2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 4, afbeelding 1 van 1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 5, afbeelding 1 van 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 5, afbeelding 2 van 2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: stap 6, afbeelding 1 van 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: stap 6, afbeelding 2 van 2
    • Remove the two 14 mm screws on the plastic plate holding the power cord with a flat head screwdriver.
    • Lift off the plastic plate holding the power cord with a tweezer.
  7. RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 7, afbeelding 1 van 1
    • Pull the switchboard out slowly.
    • The power switch will also come out. Set it on the side.
  8. RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 8, afbeelding 1 van 2 RotoZip Rebel REB01 Type 2 Power Cord Replacement: stap 8, afbeelding 2 van 2
    • Pinch the two white clips with your thumb while simultaneously removing the black and white wires.
    • Remove the power cord from the saw.
    • When reassembling, make sure to plug the black wire into the top clip.
Conclusie
Ezzeddeen Gazali
81 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-4, Livingston Fall 2016 Lid van Cal Poly, Team 4-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 626
