Ga door naar hoofdinhoud
Rotary Multi Selector Wheel Removal
Wat je nodig hebt
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: stap 1, afbeelding 1 van 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: stap 1, afbeelding 2 van 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: stap 1, afbeelding 3 van 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: stap 2, afbeelding 1 van 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: stap 3, afbeelding 1 van 2 Rotary Multi Selector Wheel Removal, Detaching Ribbon: stap 3, afbeelding 2 van 2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: stap 4, afbeelding 1 van 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: stap 4, afbeelding 2 van 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: stap 4, afbeelding 3 van 3
    • Lift up the metal cover and its button slowly using the tweezers.
Conclusie
Andrew Lau
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-56, Johann Spring 2013 Lid van Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 14
Altijd: 512
