Ga door naar hoofdinhoud
Rosewill NEON M62 Sensor Cover Replacement
Wat je nodig hebt
  1. Rosewill NEON M62 Sensor Cover Replacement, Bottom Panel: stap 1, afbeelding 1 van 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Sensor Cover Replacement: stap 2, afbeelding 1 van 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Sensor Cover Replacement: stap 3, afbeelding 1 van 2 Rosewill NEON M62 Sensor Cover Replacement: stap 3, afbeelding 2 van 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Sensor Cover Replacement, Sensor Cover: stap 4, afbeelding 1 van 1
    • Remove the four 5 mm screws with a Philips #00 screwdriver.
  5. Rosewill NEON M62 Sensor Cover Replacement: stap 5, afbeelding 1 van 2 Rosewill NEON M62 Sensor Cover Replacement: stap 5, afbeelding 2 van 2
    • Remove the center clear plastic piece, known as the sensor cover.
Conclusie
Sean Turk
217 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G2
3 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 88
