Inleiding
Need to replace those rubber cushions and washers on the trucks of your classic roller skates? No problem. The only tool required is a 14 mm wrench or ratchet and socket. Replacement cushions and washers are available online or at any respectable skate shop.
Wat je nodig hebt
Using a 14 mm wrench, loosen and extract the bolt from the base plate.
Bijna klaar!
Conclusie
