Ga door naar hoofdinhoud
Roland TR-505 Switch-board Replacement
  1. Roland TR-505 Switch-board Replacement, Removing the dials: stap 1, afbeelding 1 van 3 Roland TR-505 Switch-board Replacement, Removing the dials: stap 1, afbeelding 2 van 3 Roland TR-505 Switch-board Replacement, Removing the dials: stap 1, afbeelding 3 van 3
    • With the dials in front of you carefully pull them up and away from the hide and shaft
  2. Roland TR-505 Switch-board Replacement, Removing the bottom screws: stap 2, afbeelding 1 van 1
    • Remove these Philips PH1 screw
    • Not all screws are the same,make sure to keep them organised:-)
  3. Roland TR-505 Switch-board Replacement, Opening the device: stap 3, afbeelding 1 van 2 Roland TR-505 Switch-board Replacement, Opening the device: stap 3, afbeelding 2 van 2
    • Carefully separate the 2 half’s
    • If it’s not coming apart you may need a plastic pry tool to assist you
    • Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
  4. Roland TR-505 Switch-board Replacement, Unplugging the connectors: stap 4, afbeelding 1 van 1
    • Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
    • Do not pull on the cable itself as you risk pulling the cables out of the connector
  5. Roland TR-505 Switch-board Replacement, Disassembling the top half: stap 5, afbeelding 1 van 1
    • with the connectors disconnected you can lift the top half away.
    • to take the switchboard off take out these PH 1 Philips screws
    • Thumbs up to Roland for adding arrows to where the screws are on the switch-board:-)
  6. Roland TR-505 Switch-board Replacement, Removing the Switch-board: stap 6, afbeelding 1 van 1
    • Carefully lift the switch-board out
Conclusie
Één andere persoon heeft deze handleiding voltooid.
HelloMacOS
26.654 Reputatie
11 handleidingen geschreven
Repair is War on Entropy Lid van Repair is War on Entropy
Community
29 Leden
1.759 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 139
