Ga door naar hoofdinhoud
Roku Streaming Stick Motherboard Port replacement
Wat je nodig hebt
  1. Roku Streaming Stick Motherboard Port replacement, Roku Streaming Stick Motherboard Port: stap 1, afbeelding 1 van 1
    • Grab the blue plastic opening tool to open the Roku Streaming Stick 3500R.
  2. Roku Streaming Stick Motherboard Port replacement: stap 2, afbeelding 1 van 2 Roku Streaming Stick Motherboard Port replacement: stap 2, afbeelding 2 van 2
    • Place the blue plastic opening tool into one of the cracks on the back of the Roku to pop open the Roku Streaming Stick 3500R. Be careful not to break anything while removing the back.
  3. Roku Streaming Stick Motherboard Port replacement: stap 3, afbeelding 1 van 1
    • Once you have removed the cover, you can now access the motherboard of the Roku Streaming Stick.
  4. Roku Streaming Stick Motherboard Port replacement: stap 4, afbeelding 1 van 2 Roku Streaming Stick Motherboard Port replacement: stap 4, afbeelding 2 van 2
    • Remove the motherboard by grabbing a hold of the micro-usb port, or you can also use tweezers to grab a hold of it and pull it out. But be careful with where you grab the motherboard.
  5. Roku Streaming Stick Motherboard Port replacement: stap 5, afbeelding 1 van 3 Roku Streaming Stick Motherboard Port replacement: stap 5, afbeelding 2 van 3 Roku Streaming Stick Motherboard Port replacement: stap 5, afbeelding 3 van 3
    • Once you identify the HDMI port and the micro-usb port, you can investigate to see which port may be damaged.
  6. Roku Streaming Stick Motherboard Port replacement: stap 6, afbeelding 1 van 2 Roku Streaming Stick Motherboard Port replacement: stap 6, afbeelding 2 van 2
    • Once you have identified the problem you can then desolder the points at the HDMI as highlighted, or at the micro-usb ports.
    • If the soldering gun, or iron is set too high you then run the risk of destroying the motherboard altogether, or even damaging the wireless antennas.
Conclusie
If the replacement of the motherboard does not work, another part may need to be replaced.
For reassembly, follow instructions in reverse order.
4 andere personen hebben deze handleiding voltooid.
Andy Miller
203 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G2, Wilson Spring 2018 Lid van IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 Leden
3 handleidingen geschreven
Één opmerking
Any idea where to buy a new hdmi port to solder on?
exxonchavez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 3,775
