Ga door naar hoofdinhoud
Roku 4 Remote Control Motherboard Replacement
Wat je nodig hebt
  1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: stap 1, afbeelding 1 van 1
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
  2. Roku 4 Remote Control Motherboard Replacement: stap 2, afbeelding 1 van 2 Roku 4 Remote Control Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
  3. Roku 4 Remote Control Motherboard Replacement: stap 3, afbeelding 1 van 2 Roku 4 Remote Control Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the batteries from the battery compartment.
  4. Roku 4 Remote Control Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
  5. Roku 4 Remote Control Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
  6. Roku 4 Remote Control Motherboard Replacement: stap 6, afbeelding 1 van 3 Roku 4 Remote Control Motherboard Replacement: stap 6, afbeelding 2 van 3 Roku 4 Remote Control Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
Conclusie
Hank Harrison
449 Reputatie
3 handleidingen geschreven
Baylor, Team S5-G4, Williams Spring 2017 Lid van Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 1,625
