Ga door naar hoofdinhoud
Roku 3 Remote Control Motherboard Replacement
Wat je nodig hebt
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: stap 1, afbeelding 1 van 1
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: stap 2, afbeelding 1 van 2 Roku 3 Remote Control Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: stap 4, afbeelding 1 van 2 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: stap 4, afbeelding 2 van 2
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: stap 5, afbeelding 1 van 2 Roku 3 Remote Control Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: stap 6, afbeelding 1 van 2 Roku 3 Remote Control Motherboard Replacement: stap 6, afbeelding 2 van 2
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Isobelle Espiritu
591 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-2, Livingston Fall 2016 Lid van Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Leden
6 handleidingen geschreven
4 opmerkingen
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - Antwoord
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - Antwoord
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 5,093
