Inleiding
The radio’s antenna can become unscrewed from normal handling, possibly tearing the antenna cable. This guide will explain how to replace the antenna of your Roberts Expression DAB-FM Digital Portable Radio.
Wat je nodig hebt
Inspect the solder joints that join the coaxial cable to the antenna. If the coaxial cable solder joints are loose, frayed, or snapped, re-soldering is required.
If the solder joints are damaged, desolder the coaxial cable from the antenna base.
Carefully solder the antenna signal element to the small wire in the core of the coaxial cable. Ensure the core wire can not touch any other electrical connections.
Gently arrange the coaxial cable so that the outer shielding of the coaxial cable can be soldered to the ground of the antenna. Check that the solder joint is sturdy.
4 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Great stuff - very easy once I knew to prise the grill off! Thanks.
Thank You for that information, Martin. I’ve been scratching my head as to how to dismantle one of these radios, despite having been in the repair trade for over 40 years.
Vielen Dank für diese tolle Anleitung
