Ga door naar hoofdinhoud
Roberts Expression DAB/FM Digital Portable Radio Antenna Replacement
Wat je nodig hebt
  1. Roberts Expression DAB/FM Digital Portable Radio Antenna Replacement, Antenna: stap 1, afbeelding 1 van 1
    • Gently pry the speaker grill from the radio, using a spudger if needed.
    • Pry gently as to avoid bending the speaker grill.
  2. Roberts Expression DAB/FM Digital Portable Radio Antenna Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 11 Phillips screws on the rear panel, taking note of the varying sizes of screws.
    • Small Phillips screws
    • Medium Phillips screws
    • Large Phillips screws
  3. Roberts Expression DAB/FM Digital Portable Radio Antenna Replacement: stap 3, afbeelding 1 van 1
    • The screw holding the antenna in place may have fallen out, and would be loose in the device or stuck to a speaker magnet. Re-secure the screw if it was loose.
    • Inspect the solder joints that join the coaxial cable to the antenna. If the coaxial cable solder joints are loose, frayed, or snapped, re-soldering is required.
    • If the solder joints are damaged, desolder the coaxial cable from the antenna base.
    • Soldering irons can reach temperatures of up to 900 degrees F. Handle with caution.
    • Carefully solder the antenna signal element to the small wire in the core of the coaxial cable. Ensure the core wire can not touch any other electrical connections.
    • Gently arrange the coaxial cable so that the outer shielding of the coaxial cable can be soldered to the ground of the antenna. Check that the solder joint is sturdy.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Martin Schleiermacher
602 Reputatie
2 handleidingen geschreven
7 opmerkingen
Great stuff - very easy once I knew to prise the grill off! Thanks.
Keith Batten - Antwoord
grate stuff, my radyo is werking againe , tanks
Ian Glish - Antwoord
Thank You for that information, Martin. I’ve been scratching my head as to how to dismantle one of these radios, despite having been in the repair trade for over 40 years.
mikefortythree - Antwoord
OK, so English isn’t Martin’s first language, aber wieviele Leuten Deutsche sprechen koennen? Ausgezeichnet Martin - und vielen Dank für Ihre Hilfe
Nick B - Antwoord
Vielen Dank für diese tolle Anleitung
Rolf Willing - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 4,242
