Ga door naar hoofdinhoud
Rival Mini Chopper MC-67BL Motor Replacement
Wat je nodig hebt
  1. Rival Mini Chopper MC-67BL Motor Replacement, Turning Gears: stap 1, afbeelding 1 van 2 Rival Mini Chopper MC-67BL Motor Replacement, Turning Gears: stap 1, afbeelding 2 van 2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Motor Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Motor Replacement: stap 3, afbeelding 1 van 1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Motor Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Motor Replacement: stap 5, afbeelding 1 van 2 Rival Mini Chopper MC-67BL Motor Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Motor Replacement: stap 6, afbeelding 1 van 1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Motor Replacement: stap 7, afbeelding 1 van 1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Motor Replacement: stap 8, afbeelding 1 van 3 Rival Mini Chopper MC-67BL Motor Replacement: stap 8, afbeelding 2 van 3 Rival Mini Chopper MC-67BL Motor Replacement: stap 8, afbeelding 3 van 3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Motor Replacement, Motor: stap 9, afbeelding 1 van 1
    • Pull the shaft from the base.
    • This will require a bit of force.
  10. Rival Mini Chopper MC-67BL Motor Replacement: stap 10, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver and unscrew the two base screws.
  11. Rival Mini Chopper MC-67BL Motor Replacement: stap 11, afbeelding 1 van 1
    • Unwind the power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Motor Replacement: stap 12, afbeelding 1 van 2 Rival Mini Chopper MC-67BL Motor Replacement: stap 12, afbeelding 2 van 2
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body. The motor and power cable are connected to this panel.
  13. Rival Mini Chopper MC-67BL Motor Replacement: stap 13, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the screws that attach the motor to the base.
  14. Rival Mini Chopper MC-67BL Motor Replacement: stap 14, afbeelding 1 van 1
    • Pull the power cord wires up from underneath the wire hook on the side of the motor.
  15. Rival Mini Chopper MC-67BL Motor Replacement: stap 15, afbeelding 1 van 2 Rival Mini Chopper MC-67BL Motor Replacement: stap 15, afbeelding 2 van 2
    • Carefully cut into the black wire casing for both wires using a small knife, and peel away the black casing.
    • Only cut deep enough to remove the casing.
    • For reassembly you will need black electrical tape to keep the wires from being exposed.
  16. Rival Mini Chopper MC-67BL Motor Replacement: stap 16, afbeelding 1 van 1
    • Use a soldering kit to remove solder from the circuit board for the red wire.
    • Follow this soldering guide if you need extra help!
  17. Rival Mini Chopper MC-67BL Motor Replacement: stap 17, afbeelding 1 van 1
    • Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
    • For reassembly the copper wires will need to be soldered together.
  18. Rival Mini Chopper MC-67BL Motor Replacement: stap 18, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the single 4.76-mm screw from the motor base to finish removing the motor.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Roxanne
522 Reputatie
4 handleidingen geschreven
Cal Poly, Team 4-29, Amido Fall 2013 Lid van Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 3,349
