Ga door naar hoofdinhoud
Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement
Wat je nodig hebt
  1. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: stap 1, afbeelding 1 van 2 Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to unplug the kettle base.
    • Using Torx screwdriver, open kettle base and remove PCB
    • One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
  2. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap potential problem: stap 2, afbeelding 1 van 1
    • The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
    • The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
    • Line input
    • Switching regulator
    • LDO and MCU
  3. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap problem (2): stap 3, afbeelding 1 van 1
    • Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
    • Red arrow: Pulsed 320V (220VAC) switching regulator
    • Blue arrow: 4.4V LDO supply voltage for MCU
  4. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Microcontroller replacement: stap 4, afbeelding 1 van 1
    • Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
    • Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
Conclusie
Thomas Widmaier
2.039 Reputatie
10 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.534 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 359
