Inleiding
Many water heaters / kettles use systems from Strix. The one I got is sold by German company Ritter.
Be extremely careful when operating the PCB out of the box as it may contain voltages of up to 320VDC!
Wat je nodig hebt
Using Torx screwdriver, open kettle base and remove PCB
One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
Line input
Switching regulator
LDO and MCU
Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
Red arrow: Pulsed 320V (220VAC) switching regulator
Blue arrow: 4.4V LDO supply voltage for MCU
Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
