Inleiding
Ga naar stap 1 ↓In this guide, you will be shown how to take apart and replace the Housing unit of the Ring Video Doorbell step-by-step. You will need a Phillips screwdriver size PH00 and a Plastic Tool Opener.
Wat je nodig hebt
Gereedschap
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
Pry open the aluminium plate using the Plastic Opening Tool(s).
Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen onder de handleiding
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
Hello need rear panel that battery sits on 1st generation thanks
