Ga door naar hoofdinhoud
Ring Video Doorbell Housing Replacement
Wat je nodig hebt
  1. Ring Video Doorbell Housing Replacement, Housing: stap 1, afbeelding 1 van 3 Ring Video Doorbell Housing Replacement, Housing: stap 1, afbeelding 2 van 3 Ring Video Doorbell Housing Replacement, Housing: stap 1, afbeelding 3 van 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
    Vraag FixBot
  2. Ring Video Doorbell Housing Replacement: stap 2, afbeelding 1 van 3 Ring Video Doorbell Housing Replacement: stap 2, afbeelding 2 van 3 Ring Video Doorbell Housing Replacement: stap 2, afbeelding 3 van 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
    Vraag FixBot
  3. Ring Video Doorbell Housing Replacement: stap 3, afbeelding 1 van 3 Ring Video Doorbell Housing Replacement: stap 3, afbeelding 2 van 3 Ring Video Doorbell Housing Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
    Vraag FixBot
  4. Ring Video Doorbell Housing Replacement: stap 4, afbeelding 1 van 1
    • Remove the plastic film using the Plastic Tool Opener.
    Vraag FixBot
Conclusie
3 andere personen hebben deze handleiding voltooid.
Abdulrahman
709 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G5, Cheng Spring 2018 Lid van USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Leden
10 handleidingen geschreven
2Gids Commentaar
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
Charlie Adamson - Antwoord Deel
Hello need rear panel that battery sits on 1st generation thanks
Jerry Narain - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 91
Altijd: 4,010
