Ga door naar hoofdinhoud
Ring Video Doorbell Battery Replacement
Wat je nodig hebt
    1. Ring Video Doorbell Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Ring Video Doorbell Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Ring Video Doorbell Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
      • Pry open the aluminium plate using the Plastic Opening Tool(s).
      • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Ring Video Doorbell Battery Replacement: stap 2, afbeelding 1 van 3 Ring Video Doorbell Battery Replacement: stap 2, afbeelding 2 van 3 Ring Video Doorbell Battery Replacement: stap 2, afbeelding 3 van 3
      • Pry open the back case as shown using the Plastic Opening Tool.
      • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
      • Disconnect the battery from motherboard by carefully pulling up on the connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Abdulrahman
709 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G5, Cheng Spring 2018 Lid van USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Leden
40 handleidingen geschreven
7Gids Commentaar
Where do I get a replacement battery?
William Price - Antwoord Deel
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Antwoord Deel
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Antwoord Deel
can it be sent to the manufacturers for a replacement
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Daniel Wise - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 353
Altijd: 20,386
