Inleiding
In this guide, we will show you how to replace the battery in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
Wat je nodig hebt
Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
Bijna klaar!
Conclusie
