Ga door naar hoofdinhoud
Ring Stick Up Cam Speakers Replacement
Wat je nodig hebt
  1. Ring Stick Up Cam Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Speakers Replacement: stap 2, afbeelding 1 van 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Speakers Replacement: stap 4, afbeelding 1 van 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Speakers Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Speakers Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Speakers Replacement, Camera: stap 7, afbeelding 1 van 1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Speakers Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Speakers Replacement: stap 9, afbeelding 1 van 1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Speakers Replacement: stap 10, afbeelding 1 van 1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Speakers Replacement: stap 11, afbeelding 1 van 1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Speakers Replacement: stap 12, afbeelding 1 van 1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Speakers Replacement: stap 13, afbeelding 1 van 1
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Speakers Replacement, Microphone: stap 14, afbeelding 1 van 1
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Speakers Replacement: stap 15, afbeelding 1 van 1
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Speakers Replacement: stap 16, afbeelding 1 van 1
    • Use your hands to remove the daughterboard containing the microphone from the housing.
  17. Ring Stick Up Cam Speakers Replacement, Speakers: stap 17, afbeelding 1 van 1
    • Using a plastic opening tool, remove both of the speakers.
Conclusie
Chunyue Liu
273 Reputatie
2 handleidingen geschreven
UC Davis, Team S18-G3, Lore Winter 2019 Lid van UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 1,100
