Ga door naar hoofdinhoud
Ring Stick Up Cam Battery Motherboard Replacement
Wat je nodig hebt
  1. Ring Stick Up Cam Battery Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    Vraag FixBot
    Voeg opmerking toe
  2. Ring Stick Up Cam Battery Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Gently pull down to separate the stand from the camera body.
    Vraag FixBot
    Voeg opmerking toe
  3. Ring Stick Up Cam Battery Motherboard Replacement: stap 3, afbeelding 1 van 2 Ring Stick Up Cam Battery Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
    Vraag FixBot
    Voeg opmerking toe
  4. Ring Stick Up Cam Battery Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Halberd Spudger
    $2.99
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
    Vraag FixBot
    Voeg opmerking toe
  5. Ring Stick Up Cam Battery Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Ring Stick Up Cam Battery Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Ring Stick Up Cam Battery Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Ring Stick Up Cam Battery Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Pry the inside panel open using your hands or a spudger if necessary.
    Vraag FixBot
    Voeg opmerking toe
  9. Ring Stick Up Cam Battery Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  10. Ring Stick Up Cam Battery Motherboard Replacement: stap 10, afbeelding 1 van 2 Ring Stick Up Cam Battery Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Lift the motherboard from the camera body with the halberd spudger.
    Vraag FixBot
    Voeg opmerking toe
  11. Ring Stick Up Cam Battery Motherboard Replacement: stap 11, afbeelding 1 van 2 Ring Stick Up Cam Battery Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
    Vraag FixBot
    Voeg opmerking toe
  12. Ring Stick Up Cam Battery Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
    Vraag FixBot
    Voeg opmerking toe
  13. Ring Stick Up Cam Battery Motherboard Replacement: stap 13, afbeelding 1 van 2 Ring Stick Up Cam Battery Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Vanessa Hasbrouck
366 Reputatie
2 handleidingen geschreven
Marist, Team 1-1, Chaterdon Spring 2023 Lid van Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Leden
8 handleidingen geschreven
1Gids Commentaar
Would like to see a chip identification teardown in the future please 😊
Bryan Watson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 51
Altijd: 1,086
