Inleiding
Ga naar stap 1 ↓If you are experiencing issues with the microphone of your Ring Stick Up Cam Battery (3rd generation, model number 5UM7E5), this guide will help you access the microphone to replace it. Since the microphone is protected by metal and plastic structures, you will need tools such as a 00 mm Phillips-head screwdriver, spudger tool, hook tool, etc to access the location of the microphone. We recommend having a cleared space to work that is both clean and dry.
Wat je nodig hebt
Gereedschap
Spudger4.9
Turn the camera so the lens is facing away from you, and the back is facing towards you.
Place one hand securely on the base and the other on the stand.
Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
Gereedschap gebruikt in deze stap:Halberd Spudger$2.99
Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
Orient your device so that the interior of the camera body is facing the ceiling.
Remove the two 4 mm screws connecting the metal protective piece to the camera body using a Phillips #00 screwdriver.
Use the hook end of the halberd spudger to carefully lift the microphone from the base.
