Ga door naar hoofdinhoud
Ring Stick Up Cam Battery Microphone Replacement
Wat je nodig hebt
  1. Ring Stick Up Cam Battery Microphone Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    Vraag FixBot
    Voeg opmerking toe
  2. Ring Stick Up Cam Battery Microphone Replacement: stap 2, afbeelding 1 van 1
    • Gently pull down to separate the stand from the camera body.
    Vraag FixBot
    Voeg opmerking toe
  3. Ring Stick Up Cam Battery Microphone Replacement: stap 3, afbeelding 1 van 2 Ring Stick Up Cam Battery Microphone Replacement: stap 3, afbeelding 2 van 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
    Vraag FixBot
    Voeg opmerking toe
  4. Ring Stick Up Cam Battery Microphone Replacement, Motherboard: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Halberd Spudger
    $2.99
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
    Vraag FixBot
    Voeg opmerking toe
  5. Ring Stick Up Cam Battery Microphone Replacement: stap 5, afbeelding 1 van 1
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Ring Stick Up Cam Battery Microphone Replacement: stap 6, afbeelding 1 van 1
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Ring Stick Up Cam Battery Microphone Replacement: stap 7, afbeelding 1 van 1
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Ring Stick Up Cam Battery Microphone Replacement: stap 8, afbeelding 1 van 1
    • Pry the inside panel open using your hands or a spudger if necessary.
    Vraag FixBot
    Voeg opmerking toe
  9. Ring Stick Up Cam Battery Microphone Replacement: stap 9, afbeelding 1 van 1
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  10. Ring Stick Up Cam Battery Microphone Replacement: stap 10, afbeelding 1 van 2 Ring Stick Up Cam Battery Microphone Replacement: stap 10, afbeelding 2 van 2
    • Lift the motherboard from the camera body with the halberd spudger.
    Vraag FixBot
    Voeg opmerking toe
  11. Ring Stick Up Cam Battery Microphone Replacement: stap 11, afbeelding 1 van 2 Ring Stick Up Cam Battery Microphone Replacement: stap 11, afbeelding 2 van 2
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
    Vraag FixBot
    Voeg opmerking toe
  12. Ring Stick Up Cam Battery Microphone Replacement: stap 12, afbeelding 1 van 1
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
    Vraag FixBot
    Voeg opmerking toe
  13. Ring Stick Up Cam Battery Microphone Replacement: stap 13, afbeelding 1 van 2 Ring Stick Up Cam Battery Microphone Replacement: stap 13, afbeelding 2 van 2
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  14. Ring Stick Up Cam Battery Microphone Replacement, Camera: stap 14, afbeelding 1 van 1
    • Orient your device so that the interior of the camera body is facing the ceiling.
    Vraag FixBot
    Voeg opmerking toe
  15. Ring Stick Up Cam Battery Microphone Replacement: stap 15, afbeelding 1 van 1
    • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  16. Ring Stick Up Cam Battery Microphone Replacement: stap 16, afbeelding 1 van 1
    • Grab and twist the camera counterclockwise with your thumb and index finger.
    Vraag FixBot
    Voeg opmerking toe
  17. Ring Stick Up Cam Battery Microphone Replacement: stap 17, afbeelding 1 van 2 Ring Stick Up Cam Battery Microphone Replacement: stap 17, afbeelding 2 van 2
    • Using your fingers, lift out the camera component including the camera lens and the attached wire.
    Vraag FixBot
    Voeg opmerking toe
  18. Ring Stick Up Cam Battery Microphone Replacement, Microphone: stap 18, afbeelding 1 van 1
    • Remove the two 4 mm screws connecting the metal protective piece to the camera body using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  19. Ring Stick Up Cam Battery Microphone Replacement: stap 19, afbeelding 1 van 1
    • Using your fingers, carefully pinch the white connector attached to the black cable, and gently pull it out of its slot on the daughterboard.
    Vraag FixBot
    Voeg opmerking toe
  20. Ring Stick Up Cam Battery Microphone Replacement: stap 20, afbeelding 1 van 1
    • Rotate the camera body to a comfortable position.
    • Use the spudger to pry the metal component from the camera body.
    • The daughterboard and microphone should now be exposed.
    Vraag FixBot
    Voeg opmerking toe
  21. Ring Stick Up Cam Battery Microphone Replacement: stap 21, afbeelding 1 van 1
    • Gently remove the daughterboard from the base with your hands or the spudger if necessary.
    Vraag FixBot
    Voeg opmerking toe
  22. Ring Stick Up Cam Battery Microphone Replacement: stap 22, afbeelding 1 van 2 Ring Stick Up Cam Battery Microphone Replacement: stap 22, afbeelding 2 van 2
    Halberd Spudger
    $2.99
    • Use the hook end of the halberd spudger to carefully lift the microphone from the base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Caroline Smith
267 Reputatie
2 handleidingen geschreven
Marist, Team 1-1, Chaterdon Spring 2023 Lid van Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 68
Altijd: 1,006
