Ga door naar hoofdinhoud
Ring Stick Up Cam Battery Battery Replacement
  1. Ring Stick Up Cam Battery Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    Vraag FixBot
    Voeg opmerking toe
  2. Ring Stick Up Cam Battery Battery Replacement: stap 2, afbeelding 1 van 1
    • Gently pull down to separate the stand from the camera body.
    Vraag FixBot
    Voeg opmerking toe
  3. Ring Stick Up Cam Battery Battery Replacement: stap 3, afbeelding 1 van 2 Ring Stick Up Cam Battery Battery Replacement: stap 3, afbeelding 2 van 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Caroline Smith
267 Reputatie
2 handleidingen geschreven
Marist, Team 1-1, Chaterdon Spring 2023 Lid van Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 199
Altijd: 2,140
