Inleiding
This guide will provide a clear step-wise procedure on how to repair a broken temple (arm) on a pair of rimless glasses. Glasses can be bent or broken in all sorts of ways, and wearers of spectacles are surely familiar with the plight of a damaged frame.
This is a very simple process which can save you money when you need to fix your rimless glasses at home. Every time a displacement occurs, you’ll be able to fix your glasses on your own. All you need to have is a rimless glasses repair tool kit which consists of a glasses plier, a silhousette, a push pin, and compression glove.
Wat je nodig hebt
Take the compression sleeves and insert them into the outer lens holes with the pins facing out.
