Inleiding
A bent SL/SR button board cable will cause the SYNC button, the LED lights and the SL/SR buttons to be unresponsive. This will make the Nintendo Switch Joy-Con unable to connect to a game console by itself without a second Joy-Con.
Before using this guide, determine that the buttons are unresponsive by going to the system settings of the game console and testing the input devices under the 'Controllers and Sensors' section.
Wat je nodig hebt
Remove the four 6 mm screws visible on the back of the Joy-Con using the Tri-point Y00 screwdriver.
To reassemble your device, follow these instructions in reverse order, starting from Step 4.
43 andere personen hebben deze handleiding voltooid.
11 opmerkingen
Nice guide. To loosen the battery compartment on my controller I had to remove te battery first. I couldn't see te top 2 screws in step 4. The battery was sticked to the bracket with some tape but removes easily. Underneath the battery were two screws.
Edit: maybe its different because I had to change the button board on the left JoyCon.
Yes! This Guide above shows the right Joycon. As for the left one there are two screws below the battery as you said!
Very helpful step-by-step guide. Thank you.
Had to change the Button Board on the left Joy-con. The screws were also located under the battery in my case. Attention: there 4 screws under the battery, two of which diagonal to each other that hold the battery compartment in place. No need to unscrew all 4.
