Inleiding
Ridgid JobMax R8620 Series E has a built-in LED light that is controlled by a switch trigger. If your LED light is functioning properly but is not turning on, it is likely that there is a problem with this switch.
Wat je nodig hebt
Pull the battery out of the case before opening the device.
Remove the nine 6mm screws on the drill cover using a Torx T10 screwdriver.
Lift off the outer casing.
Bijna klaar!
Conclusie
