Ga door naar hoofdinhoud
Ridgid GEN5X R8653 Base Assembly Replacement
Wat je nodig hebt
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: stap 1, afbeelding 1 van 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: stap 1, afbeelding 2 van 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: stap 1, afbeelding 3 van 3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: stap 2, afbeelding 1 van 3 Ridgid GEN5X R8653 Base Assembly Replacement: stap 2, afbeelding 2 van 3 Ridgid GEN5X R8653 Base Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 220
