Ga door naar hoofdinhoud
Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement
Wat je nodig hebt
  1. Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement, Outer Case: stap 1, afbeelding 1 van 2 Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement, Outer Case: stap 1, afbeelding 2 van 2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 2, afbeelding 1 van 3 Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 2, afbeelding 2 van 3 Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 2, afbeelding 3 van 3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 3, afbeelding 1 van 2 Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 3, afbeelding 2 van 2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 4, afbeelding 1 van 2 Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement: stap 4, afbeelding 2 van 2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement, Forward / Reverse Selector Switch: stap 5, afbeelding 1 van 2 Ridgid GEN5X R8611506 Foward / Reverse Selector Switch Replacement, Forward / Reverse Selector Switch: stap 5, afbeelding 2 van 2
    • Gently lift the trigger up.
    • Unhook the selector switch from the trigger.
    • Remove the selector switch.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 897
