Ga door naar hoofdinhoud
Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
Wat je nodig hebt
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: stap 1, afbeelding 1 van 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: stap 1, afbeelding 2 van 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: stap 1, afbeelding 3 van 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 2, afbeelding 1 van 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 2, afbeelding 2 van 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 2, afbeelding 3 van 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 3, afbeelding 1 van 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 3, afbeelding 2 van 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 3, afbeelding 3 van 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 4, afbeelding 1 van 2 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: stap 4, afbeelding 2 van 2
    • The motor housing assembly can now be removed from the rest of the saw.
Conclusie
Joshua Caron
792 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Julie Spring 2019 Lid van UMass Dartmouth, Team S5-G2, Julie Spring 2019
UMASSD-JULIE-S19S5G2
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 368
